audiomidijace
$179 Ea. OBO Shipped CONUS with Paypal gift payment.
Details on Voodoo Twin DELUXE mod:
Voodoo Designed? for Randall Modules
Voiced as close as possible to the very best sounding Fender Black Face Twins we serviced over the years!
Two (2) new hand-selected 12AX7 preamp tubes! (included)
Designed for improved clean tones & bluesy break up
Stays cleaner at higher volumes
Smoother harmonic content
Easier to bend & vibrato
EQ section is much more active, responsive & musical
Highs are more chimey & airy
Mids are very focused & cut through with ease
Lows are richer / more lush
Chimey or warmer / jazz'ier tones can be dialed in via EQ adjustments
Works great with pedals!
Lows, mids to highs are much more balanced across the frequency spectrum
Will cut through & sit in the mix much better live as well as in the recording studio
For best clean tone results set Master to 10 / full up & set Gain control lower
For best bluesy / overdriven tones set Master lower & set Gain full up
Includes Standard Mod? (see above)
Includes Voodoo Standard Modification?
Upgrade all Coupling & Bypass capacitors
Upgrade additional key capacitors located in audio path
Upgrade all B+ / High Voltage capacitors
Tone is more open and professional sounding
EQ section is more musical sounding
Deeper / richer lows
Highs are smoother and more open
Mids are better focused
Improved feel - Smoother & easier to play
Improved harmonics
Over all tone is more three dimentional / 3D
Classic Blackface cleans with singing bluesy overdrive
A must for touring musicians, engineers and producers!
Deluxe Mod? will give you the best tone, feel and performance
Cheers,
Jace
Improved harmonics
Cheers,
Jace
