RM50 - Channel 1 doesn't switch off
lintycreep
PA
Anyone else run into channel one not shutting off when switching channels? Used a little deoxit on the footswitch jack and module contacts without success.
Sorry, I am no help.
If it does it regardless of which modules are in the slots, then there is something wrong in the switching circuit. If you have a competent amp tech you trust, they should be able to fix it. I don’t think the switching circuit is that exotic and can probably be fixed with standard parts a good amp tech should be able to source.
Appreciate the response. It's been sitting around collecting dust for awhile, but I don't recall it not working before. I was hoping it be a easy fix, so I could throw it up on Craigslist. Guess I'll just keep it.
Thanks
