Pin-out for the edge connector?
For you Bob Villa types that modify modules
Moderator: Jaded Faith
goldtop
Post by goldtop » Sat Apr 11, 2015 5:06 am
Hi all, newbie here, having just picked up an RM100C with 4 modules (Deluxe, Plexi, XTC, UltraXL). It was a steal (at far less than the cost of the 4 modules alone). I'd always wondered about the MTS amps but never tried one.
Anyhoo, a big part of the appeal are the modular construction and modding potential allows so many possibilities. I've had a look at some of the mods and they all look and sound very appealing.
For my own approach, though, I'd first like to find out the pin-out of the edge connector. Anyone have it?
(I did a search and then found a posting that had some strange CAPCAD drawings/schematics but don't have the software to open those.)
goldtop
Post by goldtop » Mon Apr 13, 2015 7:31 am
Not a busy forum, or those that have worked it all out are keeping the info to themselves? :D
No worries, I'll get the spare module out, trace some tracks and try to reverse engineer it.
(Of course, if the info is here and I've overlooked it while going through the DIY area, please point me in the right direction!)
goldtop
Post by goldtop » Mon Apr 13, 2015 3:25 pm
Well, they say that the first sign of madness is talking to yourself, but I don't care. :)
Managed to find the edge connector detail on a schematic, the latter being linked to from this site. The actual link was broken, but a quick search and I see that some kind MTS soul has put it on his Dropbox: https://dl.dropboxusercontent.com/u/3602793/SL_1.pdf
So that's a head start on sussing out the edge connector. I'll investigate further and draw it up and post it here ASAP.
suphuckers
Post by suphuckers » Mon Apr 13, 2015 3:34 pm
goldtop wrote:Well, they say that the first sign of madness is talking to yourself, but I don't care. :)
I don't have much or anything to add (which most people round here will tell you is rare for me goldtop) but I'm reading/listening ;)
...just so you know you're not entirely insane.
"Dude, you're easily the gnarliest guy I've seen around here in years"
59' Sears Wish Book Cowboy Guitar w/ Christmas Box, AXL Acoustic Guitar Pickup w/ E-pin Jack, Marshall MS-2 1/2 Stack Classic. ohhh, and some modules.
goldtop
Post by goldtop » Tue Apr 14, 2015 10:41 am
Wellllllllll, you could be a figment of my imagination... Do you mind if I call you Harvey? ;)
Anyhoo, here's my first draft:
This shows the module's edge connector's two sides (with the underside shown as if you are looking at the bottom metal plate).
If anyone can check/contradict/etc, I'll delete and update the image.
And if anyone knows the name of this type of edge connector, that'd be very useful - I can order in some matching parts.
TIA
suphuckers
Post by suphuckers » Tue Apr 14, 2015 11:39 am
goldtop wrote:Wellllllllll, you could be a figment of my imagination... Do you mind if I call you Harvey
Haha sure if it makes you feel better call me whatever you like ;)
I'm pretty interested in this but I haven't had the time to look at it yet
goldtop
Post by goldtop » Wed Apr 15, 2015 7:08 am
So I also want to get a feel for the specs for the various supplies/signals on the edge connector.
[EDIT: from the 18V DC supply] It seems pretty universal in these modules that there's two 12AX7s and just a few H11F1s, transistors and LEDs to supply. So I'd estimate that each module pulls 320-350mA or so.
For the HV, I see 320V DC marked on the various schematics here, and for two preamp valves, I guess we pull well under 10mA, and probably half that. Wonder if that's fused? In any case, it's trivial compared to the HV current supplied to the RM100's power valves.
So each module pulls perhaps 5-7W.
If anyone has a schematicc of the RM100's main power supply board, that'd be very useful for delving further! (Hint)
tschrama
Post by tschrama » Wed Apr 15, 2015 7:46 am
Power dissipation will be entirely dominated by the heaters: 6.3V x 300mA = 2W. Cold current will be higher thg :!:
four triodes: 4mA
some low voltage logic stuff: 20mA max.
I dont think the induvidual modules have, or are, fuse protected. But I would expect the HV and Heater current to be fuse protected.
I think my HV for the modules was closer to 350V. It depends offcourse on the number of modules inserted. One of the cement HV drop resistors was faulty in mine. I have only a replacement for halve the value, so my HV is a bit higher still.
my small atelier called 's-Gravenmade | Follow me www.sgravenmade.com | Join my Amp Building Workshop 14 april 2018
Good deals with: C2ply, BenMesaBoog, YouguitarHero, nitrous12, kylendm.
goldtop
Post by goldtop » Wed Apr 15, 2015 2:50 pm
Thanks for broadly confirming the details. I calc 3.6W for the pair of valves' heaters.
As far as I can see no module has anything other than 12AX7 valves, and even the low-gain "clean" modules still have two of them. :)
Emperor-TK
Post by Emperor-TK » Wed Apr 15, 2015 3:19 pm
I'm currently building a two module bass amp for Egnater/MTS modules, so I've recently been popping in here lately (just joined today).
Your pin-out looks right to me, I'd just like to add:
pins 3,4,5,6,E,F are the module's signal ground plane
pins M,N are the modules heater ground for the module's 12V Vreg
pin A is HT ground
pin 10 is filtered but unregulated DC heater voltage which gets regulated to 12V in the module
The B+ is 300V nominal but the zener diode pass-transistor regulation in the Egnaters/Randals is a little loose. It varies from 300 to 320 depending on load. I'm using a TL783 Vreg in mine for a rock solid 300V.
Emperor-TK
Post by Emperor-TK » Wed Apr 15, 2015 3:30 pm
Almost forgot, the card edge connector is a Sullins EBM12DRAS.
goldtop
Post by goldtop » Thu Apr 16, 2015 4:41 am
Much appreciated, you're a star, Emperor! I'll add the extra info to that card diagram and update it here ASAP.
And just to keep all the relevant info in one place, the datasheet for the matching female/socket is here: http://www.sullinscorp.com/catalogs/129 ... EYE_RA.pdf I'll order a few in.
It's good to see someone else working on modules that aren't more flavours of high gain, too. :) I think this platform has plenty of potential.
caliskan
Post by caliskan » Tue May 12, 2015 3:27 pm
goldtop, I've looked at the diagram of the socket that you have posted in the thread and so far I don?t think there are any issues. Power dissipation won?t be a concern here IMO. I?m glad you found the connections of the sockets. Do let us know what you made out of these modules. I?m pretty interested in finding that out.
quick-turn pcb assembly
Lucius
Post by Lucius » Wed Jan 25, 2017 5:05 pm
So I can find this again. Cheers, Lucius
Good Deals with: bj4rd (bought Ultra XL), khingpynn (traded K2 for Brahma), rlord1974
(sold Brahma)
m0jo
Re: Pin-out for the edge connector?
Post by m0jo » Thu Jun 03, 2021 1:46 am
Quick tip: Bruce Egnater (inventor of the system) is an active member of the Facebook group, so it might be worthwhile to post there and ask for verification, it's very likely that he can confirm or correct your findings. :)
Salvation Mods Twinface, Mash-all+, Sloogie, Mu?eca, Shiver (Facelift), modded XTC, stock Recto
Randall RM4 - Randall RT2/50 - Randall RM22
TT-Cabs REX V212
Pop punk bands:
www.coralsprings.nl
www.leftalive.nl
