SYN-50 Head vs SYN-5050 or other Poweramps?
Area for the Synergy line of amps and modules
RMosack
Post by RMosack » Sun Apr 11, 2021 7:09 pm
I’ve been using my SYN-2s to add channels to my Mesa Mark V. But I want to change that. May even sell that amp. So I’m looking to go more for just Synergy only.
Does anyone know any pros or cons of the SYN-50 head vs the SYN-5050 power amp?
Also, how does that power amp compare to some of the other single or even dual rack size units on the market?
j4q0
Re: SYN-50 Head vs SYN-5050 or other Poweramps?
Post by j4q0 » Tue Apr 13, 2021 9:45 am
I tried a SYN50 in a store before the pandemic, sounded just OK, but I might have not liked the cab/speaker I tried it with.
I had the SYN5050 at the same time as a Fryette 2:50:2, they sounded similar, probably the Fryette sounded more open/clear, (not sure how to describe it). I kept the Fryette because of the options and sold the SYN5050.
Mesa fifty/fifty is a great amp, different flavor and bigger bottom end (which is not necessarily better).
Mesa 2:90 has a lot more headroom, very powerfull and full sounding, the voicing options are nice but not a must.
Mesa 20/20 sounds pretty good and is loud, wouldn't recommend for metal though.
Unless you play incredibly tight modern metal you probably don't need more than a 50w amp if you want the headroom, or even 20w depending on your style of music.
Other options I know that are well regarded but I haven't tried: KSR compact power amp, Myasnikov custom amps, Engl, Randall RT250, Ffryette power station, Seymour Duncan power stage.
RMosack
Post by RMosack » Tue Apr 20, 2021 9:07 am
Thanks for the replies. I'm not familiar with a few of those. The ENGL stuff is interesting. It seems to be similar feature and price-wise with the Fryette stuff (all tube, 2u sized, similar featues, etc.). Any idea how they compare?
j4q0
Post by j4q0 » Tue Apr 20, 2021 10:39 am
Haven't tried the ENGL but all their products are top notch so I would assume it sounds pretty good.
Tube power amps I've only tried the Fryette and Mesa amps, they all sound good, just different flavors/tone and headroom.
Non tube I've tried ADA microtube power amp, sounded pretty good but doesn't have the same sonic weight as a tube amp, the Mosvalve power amps sound better but still lack that weight/punch.
Electro harmonix margnum 44 wasn't a good match for tube preamps, even with modelers you still need a graphic EQ after the preamp to make it sound closer to a real tube power amp.
aftec
Post by aftec » Tue May 11, 2021 3:27 am
That's interesting, Mesa is quite "forgiving" on their wattage, specification, the 2:90 has actually less headroom and power than a 2/50/2 :)
