Syn-2 hookup effects unit instruction
xSUITTOx
Hello, New to the forum. Been trying to contact Synergy regarding proper hook up, haven't heard back.
Just purchased a Syn-2, and a Line 6 HDPOD PRO X rack for effects. Instruction show all but a effects rack, maybe its same as the " line in and out" effects unit...
But if some can send me detail of cable instructions. The Line 6 has a separate output section and a separate Input section on back of unit.
But i will be sending the Syn=2 XRL'S to powered , 2..Mackie Thump 15a powered speakers.
Thnkyou
I'm not experienced with that gear setup, but it sounds like you just need to put the line 6 into the effects loop of the syn2?
Syn2 effect loop send <----> POD guitar in
Syn2 effects loop return <----> POD Unbalanced Output L/Mono
Debating on selling of my synergy stuff, there tech support is horrible. Another comp selling, but no support.
Did you even try what I suggested? If you aren't using a powered amp you need to treat the syn2 as an amp. Look up documentation on your line 6 into an amp as that's what you are having questions about.
