SYN2 as a looper
Henk-Jan
Is it possible to use the 'to amp-from amp' loop in the SYN2 to hook up a boost pedal?
I do have two M4's, 2 SYN2 units and a head. Alle preamps (including the preamp of the head) I switch with a VoodooLab HEX.
All loops of the HEX are in use now.
I like to use a Boss SD-1 in a programmable loop. Is it possible to hook up the SD-1 in the first SYN2 and switch the 'to amp-from amp'
and use it this way as a programmable looper?
I have to select SYN2 #1 in the loop mode to use the SD1 and simultaniously the SYN2 #2 800 module.
Will this work?
And if so, will a dedicated loop in the HEX have a 'better' performance?
