drummerguy1010
A few weeks ago, my RM100 started making a slight scratching/popping/static sound. It does it on all 3 channels. I've switched guitars, cables, run guitar/cable/amp, made sure all 3 modules were seated properly and did not have corrosion on the connections (they looked like they were brand new.) I'm guessing its the power amp tubes? The amp has not been moved for over a year, is played intermittently and at bedroom levels. It still has the original tubes, so maybe its time for something new?
Edit: I also looked at the back and the LED's that are supposed to show a bad tube are not lit, and all the tubes are glowing brightly. So maybe its not a bad tube?
Any suggestions?
Any suggestions?
