I recently purchased a Randall RT 2/50 and can't get it to do channel switching with my M4. Here is what I tried. (NOTE: All cables tested and are good). Opened RT and changed dip switch settings to channel 1. Then set M4 to channel 1. Cabling as follows..
Guitar -> M4 Input
M4 Output -> RT Channel 1 Input
RT Channel 1 Main -> Speaker Cabinet
RT MIDI IN -> M4 MIDI Thru
I cycled through all the channels on the M4 and assigned different channels with the RT by holding for more than 3 seconds (light did no flash like with M4). After this I tried selecting channels and the RT did not remember them. I also tried...
RT MIDI Thru -> M4 MIDI In
Just to be sure my MIDI hook up wasn't wrong.
One thing I thought of is I had S5 on the M4 in the ON position which means OMNI mode. Does this matter? I would think it wouldn't as it should make it so the M4 would work with the RT regardless of the MIDI channel.
Could it be a bad MIDI board? If so, how do I get a new one to get this thing fixed? Thanks a bunch. I realize this is my first post and I hate to start off with a problem. I've been stalking the board for a long time now. as I've been using the M4 and MOD50 together for years.
Guitar -> M4 Input
