Orren
A few weeks ago, I received and brand-spanking new Egnater MOD50 amplifier to match my Egnater 1x12 (custom loaded with a Heritage G12H). Others have talked up how fantastic the MOD50 is, and I second everything they have said. I have the SL2 (hot rodded Marshall), Erect (Dual Rectifier), and VX (Vox) dual channel modules, and they are all exceptional. I've also experimented with different power tubes. The stock EL34s sound great. I thought 6L6s sounded really nice too (a bit bottom heavy unless I pulled back on the Density control, but good). And 6V6s had a nice combination of cutting mids and top, with a lower output to boot.
But I have found my ideal power tube for that amp for "my" sound. It is...drum roll please...the THD Electronics Yellow Jacket Triode EL84! THD Yellow Jackets Triodes have a smoother feel than the normal YJs--more even, a bit lower gain, but the high gain Egnater preamps modules have SO much gain on tap, you'll never miss it. I find that with the THD YJ Triodes the MOD50 has a tight bottom, more presence, and even at high gain and MIDDLE settings, no mud! They don't turn the MOD50 into an "EL84" sounding amp, it still has its own flavor based on the preamp module you're using, but of course YJ Triodes do help the VX module sound even more Voxy!
For those who've not checked out the Egnater MOD50, its absolutely worth a look. And for those who haven't checked out the THD YJ Triodes, they're worth a look. And if you've already got a MOD50, you owe it to yourself to try out some of the THD YJ Triodes. Even if you don't like the normal YJs, even if you don't like EL84s in general, trust me, the combination is absolutely stunning.
Orren
Orren
