sepherus
- Joined
- Mar 7, 2010
- Messages
- 122
- Reaction score
- 0
I recently started jamming with another guitarist and he is used to being in one guitar projects. His tone use just massive. He uses an EC1000 with duncans straight in to his stock 5150, NS2, and JCM 800 cab loaded with t75s.
I'm using an RM50 with 6l6gc biased on the hot side. Usually an UltraXL a my dirty channel. However I don't believe it is stock. It is about as tight and tonally very similar to the Engl E530 I had before running into a rectoverb power section. I'm also stuck running an Avatar 212 for now with a v30 and a Warehouse ET65 (Celestion G12-65 clone). It is a surprisingly full cab despite it being a 212, but it still isn't a 412 by any means. I don't have the space our money to upgrade to a 412 and probably won't for a while.
It doesn't matter which of my many guitars I play, if I boost with a ts, or really almost anything. I have not tried my tweed model boosted with the ts yet, but I probably will next time. The only thing I've done that has worked is run both my channel and master vol at about 6, and had him run about 4 with my ts boosting and some slight eq changes. I could mostly hear myself then, but he didn't like the response of the amp then.
I was wondering if I swapped the 6l6s for EL34s and went with a more Marshally flavored module if that would compliment and cut well enough in stuff ranging from classic doom, some thrashier stuff and some days Suffocation style death metal. Or should I look for something else? At this point the tone is highly negotiable as long as I can cut thru better and it compliments well enough.
