iekobrid
Anthony, Jeff, Pete, Rob, Scott --
When you set out to design a module that replicates / clones / pays homage to a well known amp, do you do the final tone tweaking using equipment comparable to what's commonly matched with the original amp in question? e.g. While working on a Dual Rec preamp module, are you monitoring through a 6L6 power section and a 4x12 cab with V30s; Vox preamp module, EL84s power and 2x G12M; Marshall, EL34s & G12T75s, so on and so forth?
OR instead do you monitor each new module-in-progress through one specific power section and cab combo that you use for everything and are well familiar with as an 'average' setup?
I ask because I'm curious:
? if there are "sounds ___* when used with ABC and XYZ" type rules of thumb for each of the major modders. I put " * " instead of "best" or "most accurate" because I know those are subjective concepts --- so let's say * = "as the modder intended".
? if replicating the rest of the chain as described above (using EL84s and G12Ms with a Voxless, for example) would at best be overkill and at worst comically exaggerate the core tone to an unusable degree.
