johnodge
I've been having issues again with my RM50 LB (had it for less than a year, and second unrelated fuse issue)
I had a set of JJ 6L6 in it for about 6 months now, and recently, I was testing out my new S1S0 module, and decided to crank the amps master volume to over half. Tube 2 failure light came on, and I shut down the amp.
Changed the Tube 2 fuse to another 350-400mA fast blo 1/4 watt fuse, tried a set of JJ E34L's and biased mid setting (38-39).... ran it for a bit and turned the master up to about 1/3 volume and Tube 2 failure light came on, so I shut down the amp.
Changed the Tube 2 fuse to another 350-400mA fast blo 1/4 watt fuse, tried a different set of JJ 6L6's and didn't even get a chance to bias it and Tube 2 failure light came on, so I shut down the amp.
Any ideas out there???
Thanks
Thanks
