Jaded Faith
Many of you have had issues in the past with the ohm selectors in your RM series amps going bad. Typically the fix was to order a new RM100-H PCB to replace switches that either broke, burned up the board or fell apart. Unfortunately, this part is no longer available from Randall and will not be restocked again.
I designed a replacement PCB using a far superior switch as a drop-in replacement/upgrade. They will be in stock within the next 2-3 weeks. If you need one at anytime, email me. This switch connects directly to your Output Transformer and a failure can cause a very expensive repair.
