Replacement Ohm selector PCB's in stock soon
Jaded Faith
Hamilton, NJ
Many of you have had issues in the past with the ohm selectors in your RM series amps going bad. Typically the fix was to order a new RM100-H PCB to replace switches that either broke, burned up the board or fell apart. Unfortunately, this part is no longer available from Randall and will not be restocked again.
I designed a replacement PCB using a far superior switch as a drop-in replacement/upgrade. They will be in stock within the next 2-3 weeks. If you need one at anytime, email me. This switch connects directly to your Output Transformer and a failure can cause a very expensive repair.
