I have a RM50 combo, silver grill cloth, no reverb. The problem I'm having is after the amp has warmed up, the volume sometimes spikes up at random to a higher volume. When it first happened I thought it might just be the output tubes going bad and replaced them with some brand new ones. The problem persists, though. It happens with both modules, so I know it's not a bad module.
Last night it happened while I was playing, and I tried putting the footswitch in the master volume boost footswitch jack, thinking maybe the jack was going bad and causing these random boosts. The amp popped and fizzled for about ten seconds and then I didn't have any more problems. I'm not sure if putting the footswitch in solved it, or if the problem went away on its own coincidentally.
Anyone experienced a similar problem? Anyone have any other ideas what might be going on? I have no use for the master volume boost footswitch jack, maybe I could just defeat the jack with a 1/4" plug attached to nothing?
