parallel loop or series loop? rm 50
djkal
montreal canada
in a rm 50, i know the reverb tank is hook to the parallel loop, i would like to connect a chorus and a delay if i use them in parallel what about the reverb?
or should i put them in series loop? if so, how do i control it ?
All of those belong in the parallel loop. Series is for effects that change the 'whole' of your tone with no blend option - like a volume pedal, wah, boost, etc.
As for wiring, here's how I'd do it:
Parallel send - chorus - reverb - delay - Parallel return
Keep in mind that the effects change whatever signal goes into them, so I placed the delay last so only the chorused and reverb'd signal would get delay added to it, rather than adding chorus and reverb to the original signal and all the subsequent delayed signals.
thanks pscheoverdrive so im going to go in parallel send chorus reverb delay noise gate parallel return how is that?
question about the delay are you using the delay tank from the amp? if so the cables are not very long? thanks
