Julia
Okay, I've not been on much because I've been learning how to use this unit. Finding a host for the clip was a bear because of certain "issues", but I did. The issues being that I did a comparison with the original recording. I was going for a recorded tone to occupy a certain spot in the mix.
Although i think Youtube would have been fine with a photo, but Youtube compresses the signal even worse than I had to. I did manage to get this clip done at 192 kb/s vs. low grade 128 kb/s.
So this is my Back In Black patches for the HD500. I know what you're thinking. "Heck, just use a modded JTM and dial it." But it's not that simple. See, the tones aren't straight forward. You've got whatever mics they used. Angus' guitar is not stock. Malcolm's guitar is not stock (and I don't have a Gretsch anyway so I did it on my SG Std). Then there are various mic placements. I think I made a mistake on one of the guitar tracks at the end because it sounds like there's an echo but there isn't. Just Malcolm side I mis-timed it just before it goes back into the second verse. Forgive me. I'd been tweaking patches all day, was tired, my ears shot and just wanted it done.
I did not want to use any DAW EQ on the guitar tracks but to use what is available only on the POD HD500. So here it is. Malcolm's part is panned hard left, and Angus' part panned hard right. Bass guitar done with Reason 4 (thank you for a decent sample). Drums were Addictive Drums.
So here's the link: http://jvmforum.com/phpBB3/viewtopic.php?f=6&t=3978&p=35809#p35809
FWIW even at these settings on the JTM45 model, I can back off on my picking and if I go real light it will be clean.
Next up is the JCM800. I'm doing the Marshall stuff first, then will move on to Fender.
