Julia
I need to confirm something.
So if I pull two tubes (outer), and I have an 8 ohm 212, I plug the speaker into the 4 ohm spot, right?
If I run a hot plate for DI recording, and since it's 4 ohms, I need to put the two tubes back in to use that since the amp doesn't have a 2 ohm output, right?
I think THD people said I can also run ONE 8 ohm cab with the 4 ohm Hot Plate and connect to the 4 ohm output, right?
I'm thinking of selling one of my Avatar 212s. The one with the Vintage 30s.
