RM4 footswitch??
I went to guitar center, and the PSA-120 didn't work...
it seems that all that adapters that look like it will fit don't have a big enough hole for the prong.
what power supplies have you personally confirmed work with the pedal?
This isn't *confirmed* but I don't see why it wouldn't work...
Go to Radio Shack, get an adapter that has correct voltage OR is switchable, and has a minimum amount of ma that it can provide. They still sell the ones with the heads that you can detach - I had to get one recently for an Adrenalynn pedal and also used to use one with one of my wireless recievers.
I know it's not confirmed, but it's something. :)
Pete
my problem is they won't even plug in... the little prong in the Footswitch is too big for the standard PSA-120 type plugs-- but other than that they look like they should fit exactly.
Well, some of the radio shack adapters come with SEVERAL different plug ends. I guess I didn't make that clear.
Pete
I had the same issue. I had the Boss adapter lying around and actually wanted to use one of the wires that came with my Furman pedal board as a first choice before that. The center post is a larger size than what's standard. Like Pete said, there is a all-in-one Radio Shack adapter that has several different head sizes that will meet your needs. If I can find the right size (it's written on scrap paper somewhere around my rig) I'll repost, but Pete's given the easiest suggestion.
