Rm50 foot switch
RAdkins
Anchorage, Alaska
Just picked up a rm50. it came with a 2 switch pedal but the manual says that it should only have 1 switch. The switches are labeled channel/reverb and gain/chorus. Is this the right pedal for the amp?
Nope. Not the correct footswtich, but it will probably work to switch channels..
There aren't any other footswitching options (besides the "boost" option, but to actually use this you really need a switch with some kinda volume pot or attenuation control built in because if you just switch it "on" the boost will blow your ears out. It's just way too loud to be useable with a simple footswitch)
If you haven't already, just plug it in and one of the buttons should work to switch channels. I have used different pedals and most work. One button will do nothing of course.
