Rocktron Xpression & ground control pro
gwillis
Montreal,Canada
I would like to known if it's possible with the mode ''instant access'' of the ground control ( buttons 1 to 8 is used like a stompboxe ) and with the Xpression preset?
On the manuel of the ground control it's said that most multi effects can be use with this option like a on off pedal but i don't known how to set my Xpression
thank's
Actually, it can be done with any footswitch on a midi pedal
difference being you won't have any varying control
Now I'm quite rusty, since last time I used MIDI CC was 8 years ago
but I'm sure there are some more knowledgable peeps here that can give you the skinny
Expression pedals can give you a swell, while buttons only a switch
you'll only be controlling the highest and lowest value, nothing in between
or in case of (example) echo on/off even a expression pedal will only
switch on or of at the least or most of it's sweep
so an expression pedal can give varying values (example 0,1 ,2 ,3, 4,.... 'till 127 and back )
while a 'button' will only switch between 0 AND 127
so let's say pedal button 5 has midi number 7 (check pedal documentation)
on your rocktron unit you assign reverb on/off to cont. 7, lowest value 0 highest 127
note, this only works in 1 patch
