donmecka36
I am looking for some thing that can give me a really tight high gain with a bright upper mids crunch.my current tone is good but not great.the reason I this is because all of controls are set for the brightest settings.
my rig consists of:
rm100 with e34ls:ultra xl x2
gain:2 o'clock
bass:12 o'clock
mids:12 o'clock
treble:5 o'clock
level:9 o'clock
bright switch on
master volume:12 o'clock
presence:4 o'clock
density:9 o'clock
boss noise suppressor
mxr kfk 10 band eq:
all frequencies about 1khz are maxed out
thd hot plate:
with bright switch on
4x12 with t75's
I would like to find a way to get rid of the eq.I used to use a treble booster but that didn't work.I prefer not to use overdrive pedals.I have also tried using the eq or the treble booster in the effects loop and still no success.hopefully the right set of el34s will solve this problem.any ideas would be helpful.thanks.
my rig consists of:
gain:2 o'clock
bass:12 o'clock
mids:12 o'clock
treble:5 o'clock
level:9 o'clock
bright switch on
presence:4 o'clock
density:9 o'clock
mxr kfk 10 band eq:
thd hot plate:
4x12 with t75's
