You can use an external attenuator or London Power Scaling (drops output section's B+ while leaving heater voltage up).
Ya'll should consider using the Two Notes Torpedo's tube power amp models with MTS! They sound great and allow tube power amp color at any volume, as well as world-class convolution cab/speaker/mic sims and 5 band EQ, all under full MIDI control.
Imagine if going DI'd, Celestion Blues in a open 2X12 and EL-84's with your Vox module, various Celestion Greenbacks in a closed 4X12 with EL-34's for your Marshall modules, various open back Jensens with 6L6's with your Fender modules etc.
If using a cab then at least you can have the correct power amp tube models with any amount of powr amp color/clipping available at any volume.
I've used this with my custom 50W RM-2 since it came out, works great!
http://www.two-notes.com/en/hardware/torpedo-cab/
Jacksauce said:Is there a way to scale down the power section of the RM100?
