bduersch
Quick question... is it safe to use KT66, KT77, KT88 tubes in Egnater modular amps (particularly a MOD50)? If so, anybody know what the bias range should be?
--B
--B
Might as well buy a radio station's amp setup!Nightdare said:Quick, somebody throw in a set of KT120 valves and tell us the results (after they recovered from hearing loss ofcourse)
+1chacal said:I have put KT88s in my lynchbox with no problems. Great tubes for note clarity, dynamics and punch....
Advice of a sage. Thanks. Biasing advise?kc2eeb said:When using KT88s or 6550s, both of which have a metal base,
you will have to remove the tube retaining clip. Be sure to put the screws back in place. They hold the sockets to the chassis.
Kc2eeb, do you know the plate voltage of an RM50? I run KT66's in mine and they sound amazing but am wondering if 35ma is correct..... Have a good holidaykc2eeb said:Thanks for the kind words.
Biasing is same as 6550s and could probably go a little more, 35 to 45ma.
They're designed for up to 800 volts on the plates. The RM100 is about 510 volts.
Rod said:Kc2eeb, do you know the plate voltage of an RM50? I run KT66's in mine and they sound amazing but am wondering if 35ma is correct..... Have a good holidaykc2eeb said:Thanks for the kind words.
drewiv said:EDITED TO ASK: What's the bias range on KT88s? Anyone?
Enter your email address to join:
