XTC will not light up?
not_so_new
Post by not_so_new » Sun Aug 13, 2006 5:17 pm
Hi all.
Just bought an XTC from someone here and it does not work.... kind of frustrating.
I tried the XTC in all 4 of my slots on my RM4, tried re-seating the tubes, tried swapping the tubes with one of of my other modules. I know that the RM4 is fine because all of my other modules work.
When I turn on my RM4 all of my modules flash for just a second then the module in slot one becomes active (I assume this is normal while the modules are initializing). Anyway when the XTC is in the RM4 it does not flash when the unit it turned on and it will never light when I switch to it nor will it pass any audio.
I don't see any cold soldering joints and no obvious damage to any components... any ideas?
Thanks.
maeshuggah
Post by maeshuggah » Sun Aug 13, 2006 5:30 pm
strange. is the module properly seated in the rm4?
is the slot connector on the pcb of the module clean?
is it a black stripe or older module?
do you have a pic of the module's slot connector?
Rocktron Vendetta Vp4 preamp
(blackface, top boost, Plexi, Egnater-MHG, Grail)
Rocktron Xpression
Rocktron Midi Mate
Mesa Boogie Strategy 400 Stereo
10 Space rack
Furman M-8D Power Conditioner
Two 4x12 cabs
not_so_new
Post by not_so_new » Sun Aug 13, 2006 5:43 pm
maeshuggah wrote:strange. is the module properly seated in the rm4?
Hey Maeshuggah
Yep the module is seated just fine, I thought the same thing that is why I tried it in each slot of the RM4.
The slot connector looks to be fine. No corrosion or anything and it looks just as clean as my other modules.
I am a little confused about the black stripe stuff that I hear about on line actually. I believe all my units have a black stripe but the XTC is a little different because it has larger black stripe accost the top where the words are, "Gain" "Bass" "Middle" etc.
My module looks exactly like the XTC in this photo..
http://www.randallamplifiers.com/produc ... om_rm4.jpg
.. does that make my XTC newer or older?? Sorry for the stupid question.
No pic but I can try to get one, as I said it looks just like all my other modules. *shrug* No idea, I hope someone can help.
warmothjoe
Post by warmothjoe » Mon Aug 14, 2006 6:13 am
I guys
I'm live in France.
I have the same problem !
I change 3 modules xtc and anyone work :cry:
I wait the end of the month to return my module.
I have the SL+, plexi and blacface and they works great in any slot of the RM4.
I hope that the next one will work great.
not_so_new
Post by not_so_new » Mon Aug 14, 2006 9:39 am
Just wanted to bump this up, any ideas from anyone?
Thanks.
maeshuggah
Post by maeshuggah » Mon Aug 14, 2006 10:02 am
Perhaps its a voltage problem with the xtc module.? a bad capacitor or maybe a resistor. I know that the three resistors at the top right corner of the module 220k & 2x 4.7k (near the 2 large capacitors) can blow if its not wired right. that would make no sound.
Rocktron Xpression
Rocktron Midi Mate
10 Space rack
Two 4x12 cabs
not_so_new
Post by not_so_new » Mon Aug 14, 2006 10:43 am
maeshuggah wrote:Perhaps its a voltage problem with the xtc module.? a bad capacitor or maybe a resistor. I know that the three resistors at the top right corner of the module 220k & 2x 4.7k (near the 2 large capacitors) can blow if its not wired right. that would make no sound.
I was thinking that as well. If I had a schematic I might be able to trace it down a little better, are the drawing available on line some place.
Are their any test points on the board? I can't find them if they are.. I guess I could go point by point and see if I could track it down.
maeshuggah
Post by maeshuggah » Mon Aug 14, 2006 12:25 pm
Rocktron Xpression
Rocktron Midi Mate
10 Space rack
Two 4x12 cabs
crisden
Post by crisden » Wed Aug 16, 2006 7:01 am
I had the exact same problem with my first XTC module. I couldn't understand it, as it was brand new and every other module worked in any slot.
I returned the module and got a new one, and no problems whatsoever! You probably have a faulty module.
Crisden
Divided Sky
www.dividedskymusic.com
absorb--accept--embrace
