salvation
so, here it is, first one and only Hiwatt based MTS module:
soundclip: http://soundclick.com/share.cfm?id=11081977
Quote from our web pages: Designed after hours, days and months of developing. Some vintage legends are not easy to build into the module platform. But the Challenge was accepted and finally the H-Watt is here!
This mod uses two separate ?linked? channels, one brilliant and one normal sounding. You can blend them together in the same way as on the original.
Furthermore we replicated a true, very unusual HiWatt tonestack, using Point-To-Point wiring.
The result is replica of famous british Hi-Watt tone with unmistakeable colour and dynamic. From sparkling clean to fat or bright crunch. Gilmourize your amp.
Features
- two linked channels
- point to point wired tonestack
Features
