Push-Pull pots for Modules. Mouser Part #'s?
NuSkoolTone
Poughkeepsie, NY
Hey guys.. Instead of drilling for switches, I'd like to use some push-pull pots for mods.
Only question is what type to use, since the stock ones are PCB mounted.
Pete? Anybody?
Want to know where to source these, even Mouser#'s if possible.
I realize they might not always be the same ohm value, but once I'm in the right direction should be able to figure out the rest.
You're not going to get a part that will drop right in - push pull pots have the extra lugs for the DPDT switch where components are already there on the mts boards. I can't remember offhand what mm the pot bodies are, measure one with a ruler and use that look up your part at mouser (Xmm, dpdt) should get something. However, you'll have a fun little wiring job on your hands.
Pete
