Documented Modifications
MTS module area including module modifications
ned
Site Admin
Post by ned » Thu Mar 02, 2006 3:07 pm
There are 2 pages of module modifications currently.
Most mods can be found Here
And mods for clean (non-distortion based) modules can be found Here
burner
Post by burner » Sat Mar 04, 2006 6:36 am
I really need to try that clean mod..
My "clean" module is almost impossible to get a non distorted sound..
At least with my EMG eqipped guitars...
goldsparkletop
Post by goldsparkletop » Mon Apr 24, 2006 9:52 am
Ned, you should "sticky" this thread. I refer to these links all the time.
Gary
Henk-Jan
Post by Henk-Jan » Sat Apr 29, 2006 6:58 am
Do I understand correctly the C3 mod is the reason for the bass switch on the new Egnater dual modules?
So no need to mod these babies I guess.
Egnater M4 - Twin, Vox, SL2, Recto
Netherlands (Europe)
jimosity
Post by jimosity » Thu Jun 01, 2006 12:02 pm
burner wrote:I really need to try that clean mod..
I had that same issue as I use EMGs in all my guitars.
The clean mod solved everything.
Jim Rodgers
My MTS Sample Clips, Files and Links
2 M4s, RM100, RM50, All stock MTS Modules, 7 Dual Channels, Salvado Custom, 59RR Custom
seeker
Post by seeker » Sun Feb 18, 2007 12:02 pm
So I received my Randall Brown a few days ago, then I checked to see if the resistor R1 ( 470 ohm) was changed to 150 ohms per the documented mods. Maybe I received an old module sitting on a shelf, but it has the 470 installed. Also, the bright toggle switch stopped working after 1 use. So, I think I'll change the resistor, do the cap mod, and replace the switch.
Anyone have similar problems with these Randall modules ? Is swapping out the resistor worth it, or just leave as is ?
Thanks,
H
'91 PRS C24, Strat custom shop
(2) EGNATER M4's - modules: EG-Twin,SL,EG3,EG4,High Gain, Randall-Brown,Ultra XL
Budda SDII 18/Budda SD II 18>FX loop's (stereo)> Lexicon MPX-1>Ultracurve pro EQ>(2) Basson 2x12's
MetalMajik
Post by MetalMajik » Sun Feb 18, 2007 5:27 pm
The bright switch is not effective if you have the gain maxed out. The less you have your gain cranked the more effect the bright switch will have. Back off your gain and see if the bright switch still works
seeker
Post by seeker » Sun Feb 18, 2007 6:16 pm
What I meant is, the switch actually will not move from off to on. I can feel a gritty resistance to move to the right. Maybe the switch was over heated during assembly, or solder made it's way into the switch contacts.
Thanks,
H
MetalMajik
Post by MetalMajik » Sun Feb 18, 2007 7:02 pm
OK then. I'd say it's junk
seeker
Post by seeker » Sun Feb 25, 2007 6:52 pm
Update- Did the cap and resistor mod to the Brown. I tried the 150 ohm resistor (R1) per the documented mods, but it really destroyed the tone. I opted for a 330 ohm resistor, and .0022 (F222 Mylar film capacitor, C3). It sounds incredible now, glad I made the modifications.
H
Scott
Post by Scott » Wed Mar 07, 2007 12:38 pm
What happened to the JCM800 Tone Stack Mod for the SL+ ?
Multiple PRS's Carvin Ct, Strats Etc.
Bogner Shiva
Egnater TOL 100
Peavey Classic 50 Head
ned
Site Admin
Post by ned » Wed Mar 07, 2007 3:15 pm
It's here
Grail Tone - Amp Settings
My Rig: Egnater Mod 50 1x12 Combo w/ VX and SL2 modules
FX: Digitech GSP1101, RM4 w/ SuperV, JTM45, Plexi, XTC, KH2, TB, H9, G-Major, ton O Rockman stuff
tonesponge
Post by tonesponge » Fri Nov 23, 2007 10:28 pm
Is there a listing of specification capacitor and resistor values for the modules? I think it would be nice if we could go through and QC these components on the Randall modules. It would be really useful also to have a photo or line drawing pointing out the placement of the resistors and capacitors on the PCBs with their spec values. Are any of these things available? Thanks.
ashishk
Busted 1086 level dial
Post by ashishk » Mon Apr 28, 2008 9:06 am
Need to replace the level potentiometer on my 1086. What value/spec is this unit?
You're talking to a real electronics noob, so please be as detailed as you can.
Many thanks!
www.berserkerfox.com
ESP LTD V-500
ESP LTD EX-400
RM100 w/ JD modded Ultra XL, 1086, Blackface
Randall Straight Cab loaded w/ V30s & G-12Ts
TC Electronic G-major
Behringer FCB1010
Line 6 X2 XDR95
TheHunter
1086 mod
Post by TheHunter » Tue May 06, 2008 10:25 am
Anyone doing mods to there 1086?
MAN WHO STAND ON TOILET HIGH ON POT!!!
