Are The Synergy Heads Self-Biasing?
Tweaker74
Time for me to re-tube my SYN-30, does anyone know if they're fixed bias like a Mesa or I need to take it to my tech for re-biasing? Thanks!
As a follow-up to myself, the SYN-30 is NOT self-biasing. B.A.D. reached out to me with the following info:
"You need to rebias unless you use tubes with same numbers (if you use matching tubes using the numbers on top you shouldn't have to re-bias). The proper bias is 35mA"
Just posting in case it helps someone else out as well.
This is really helpful, thank you. I've reached out to Synergy/BAD and have yet to get a reply back.
Wait a sec...isn't the Syn30 cathode bias? Fairly certain it's a misunderstanding and he meant Syn50
