The Rossness
I've been playing my Plexi Tweed an awful lot as of late. If I want to use it for the cleaner side of things, I set the gain low and use the Tweed side of things. If I want to use the plexi side, I set the gain higher to get that Thin Lizzy side of things. But If I push the gain too high, I almost get this fuzzy kind of tone.
I've been thinking of ordering a few JF mods and thought about the Plexi-er/Tweed. Would there be a way to add an extra gain stage on the plexi side of things, while also adding a super-bright switch.
Would there be a way to add more spank on the tweed side of things?
Does anyone else use the Plexi/ Tweed. Do you like it? What would you change if you could?
