First off I again would like to thank Bduersch.
After having the amp a couple of weeks and rehearsing with it Im completly satisfied.
The amp does the most amazing hard rock tone ive ever had the pleasure to play. think Lynch, VH, Acdc, Motley crue..
the singer has a 5150 and those amps are freaking loud but for Tone the Vendetta just mixes so well .I use ch4 with 6 on the gain. mids around half treb pres around 6, density 6 as well/the amazing thing is the string to string definition. things that I used to play with the volume rolled back or had to change to the cleaner mode .no longer require this. It almost like you have a clean guitar mixed into your dirty signal and it sounds huge. Also the mid range punch is never honky nor is the treb or presence biting the amp cuts through beautifully never turning harsh.
I dont know how he does it but Bruce's voicing is really on the money in the hi gain mode for all rock.
the one thing I will say is I use the amp in modern mode and while i have more that enough gain .the death metal crowd would probaly benefit from a little more low end. I can only imagine what the MOD50, 100 sounds like after playing on this .Im not really sure what mods it comes closet to .But Bduersch has an M4 on the way so maybe he can chime in .
it sounds to me like a really well modded Marshall. and in modern mode maybe similar to a Bogner but with a tighter bottom
