How to run Syn-2 with other preamps/preamp pedals
Post new topic   Reply to topic    MTS Forum Forum Index -> Synergy Amps & Modules
chrismilne
PostPosted: Wed Jan 31, 2018 8:57 am    Post subject: How to run Syn-2 with other preamps/preamp pedals Reply with quote
What's the best way to run a Syn-2 in the fx loop of an amp, and then also be able to switch to other preamp pedals (looking at maybe Kingsley or Victory). So if i run guitar -> pedals -> amp with Synergy Syn-2 in the fx loop of the amp...could i run a preamp pedal as the first pedal in the Synergy's FX Loop? Then run those in to my time based fx pedals?
So i could have the Amp tone, plus the Synergy tone...when i bypass synergy i presume all of my fx in the Synergy's loop still work correct? If so, i guess there is no way to bypass the amps' preamp at that point...so i'm not sure how you could manage that.
This is if i don't go all Synergy, but like open options Smile I doubt i'll be touring, mostly recording, so i can rewire, just thinking about how it could be done and easily switchable (if possible).
Synergy: Syn-2, SLO, Metroplex
Randall: JTM, Clean, Blackface
Egnater: EG2
Strymon Flint and Mobius, TC Triple Delay, JHS Andy Timmons, Kemper, Ventris, Koko Boost, Carl Martin AT Compressor, Proanalog MKIV Fuzz, Ibanez TS9dx
MarcoR
PostPosted: Wed Jan 31, 2018 4:45 pm    Post subject: Reply with quote
Are you trying to toggle between three things? The Syn2, amp and the preamp pedal?
Synergy: SYN2, Friedman DS, HBE
Self Modded: Egnater B'Man, SL2X
Amps: VHT 2/50/2, RM50, Landry LS100 G3, Splawn Quick Rod, Marshall 6100LM
chrismilne
PostPosted: Wed Jan 31, 2018 4:59 pm    Post subject: Reply with quote
That would be the goal. Realizing Id have to also engage the pedal. But having it bypass any of the other preamps (amp or synergy?
Egnater: EG2
Post new topic   Reply to topic    MTS Forum Forum Index -> Synergy Amps & Modules All times are GMT - 6 Hours
