LuxxtoneBoy
- Joined
- Sep 5, 2018
- Messages
- 46
- Reaction score
- 0
Hey brother,
Can you explain how to connect 2 Syn2’s into a SYN 50/50?
I have a Synergy 2x12 cab and would like to use it in stereo (I pressume this is done by connecting the Syn 50/50 into each of the 16ohm inputs that are in the back of the cab. What outputs should I use from the Syn 50/50 to connect to the cabs and what impedance setting should I select on the Syn 50/50?
I reveived todavis my Fractal FX8, but maybe I should start with hooking up the poweramp and preamps, then I can start asking questions on how to use the 4 cable method to add the FX8.
Thanks in advance for your help.
