HELP!!! RT2-50 w 6505+112 w GT-100 w st cab
johnodge
Whitecourt, AB
I need some help, I'm not a n00b but this is puzzling me:
I am running a GT-100 and 6505+112 combo in a 4CM method. This works great! either preamps work fine!
(GT left out to 6505+112 return)
Now, I want to also run a RT2-50 power amp into a stereo cab.
How can I do this?
I was going to split the L out to go to BOTH 6505+112 and the L side of the amp, and R out to R in on the amp.
Is this right? or is there a better way?
How can I do this?
Just go mono to the 4x12, you're not gonna get stereo in such a narrow field unless you put your nose against the fabric
Yeah the RM2/50 can't be bridged so you're wasting a channel, unless you load the cab with 2 different speakersets and the amp with 2 different tubesets for some more tonal variation
