stefano5981
- Joined
- Apr 29, 2015
- Messages
- 4
- Reaction score
- 0
Good morning!! i'm stefano and I write from Italy, I have a problem with a Randall RM100 head and hope you can help me solve it. I can not change channels with a midi pedal. I opened the head and I've tried to change the MIDI channel, first ch 1 and 16 are now on the 8 I tried to change the channel on the midi pedal first 1 and 16 now on the 8 but I can not change the channel on the head. In theory on channel 56 and pressing on the pedal I should have the channel 1, channel 2 on 57 and 58 on channel 3. 'correct? I'm currently using a 7-pin cable and the pedal turns on the phantom power but is not communicating. Should I use the head with a g-major effect and after connecting with a standard 5-pin MIDI cable but pressing and holding the channel change on rm100 the g-major shows no sign that he had received no command. It 'possible that the fuse has blown dela card midi but the phantom power functions the same?
thanks in advance.
thanks in advance.
