Slashpepper
- Joined
- Jul 15, 2011
- Messages
- 67
- Reaction score
- 0
Right, slowly building up my effects chain now I've moved from a POD X3 to an RM100... First proper purchase is a buildyourownclone Overdrive 2, they're crazy cheap and I do like building things, plus I get to paint it however I like!
Right, so, plugged it in and all works excellently (to my surprise). The Overdrive really improves the Ultra tone (didn't think it would actually have that much effect!) but when I apply the boost as well (it's similar to the fulltone fulldrive 2) which boosts the post OD level the sound starts going a bit weird, like the bass gets turned up and everything else dims. Can the signal into the pre-amp be so hot that ot can't process it properly or have I wired something wrong? If I turn the boost level right down it sounds as it should, although there's not much extra headroom over the full overdrive level, so it's going to need some tweaking to match them for two usable tones. I wanted the normal overdrive to get a really good tight rythm sound and then kick in the boost for a completely saturated lead (although there's no volume difference, which means that may not work...)
Any ideas or thoughts?
