broknstuff
- Joined
- Feb 25, 2007
- Messages
- 42
- Reaction score
- 0
SOLD
I hate to do this but hard times have faced me to sell beloved my collection. Always kept in climate controlled, smoke free home. All handmade in Detroit by Bruce Egnater. If you are unfamiliar with the system, it basically allows you to switch out the preamp dual-channel modules (all tube) with an incredible sounding all tube power-section that can be run at either 50watts or at 10watts in low lower mode for more power tube saturation and different feel. Power section includes external bias points so that you can do it yourself without having to take it to a technician or risk opening up the inside of the amp and exposing yourself to high voltages. Also has a series effects loop AND a parallel loop. You get the flexibility of a digital system with the sound and feel of an all analog tube system. Each preamp has 2 channels, A and B, each with their own volume and gain (channel A is the low gain version, channel B is a higher gain version). Also compatible with Synergy modules and Randall MTS modules.
Comes with Egnater footswitch and 7-pin midi cable (carries power to footswitch, no external power supply required), and can also be controlled by any external 3rd party MIDI controller as well.
Here is a list of all the dual channel modules to choose from:
• BMAN - based on fender Bassman
• DLX - based on deluxe reverb
• SL - based on Marshall SuperLead plexi
• SL2 - based on hot-rodded Marshall sound
• EG5 - Egnater high gain modules, takes off where the EG3/4 ends. More Soldano type of lead tone
• COD - California overdrive, Egnater's take on Dumble/mesa mark IIC+
Here is a gallery with pictures of all the individuals modules listed above to choose from: https://imgur.com/a/XEioZh2
