Ok, so I've had quite a bit of run time with my two RM100's but havent used one of them in a while...(one is the metal grille, other is the solid face, looks like the Hammet version) I've noticed that my RM100M sounds WAY BETTER?? Meatier and definitely cleare than the other using the exact same EXACT premp/power tubes and modules..Same density/presence...same EQ...everthing matched exact....It hit me pretty hard this week when I switched them out due to sheer boredom (i had been using the hammet style for months while the other collected dust) I couldnt believe the difference!! Its almost like getting a new amp??? I was determined to narrow it down to tubes/cables/guitars but it IS the amp!! FWIW- The series loops are different as well- I have to change my send and return levels on my GT10 (using 4CM) because one of the heads has a much hotter loop- WTH?? Are the builds that inconsistent with these Randalls????
