PSA for anyone using a 5-pin MIDI cable and external power and external power supply on a RM100 3 button MIDI footswitch (model RF3):
The RF3's 9-12 volt DC power input uses a less common connector, 5.5/2.5mm centre positive, same as Eventide pedals. If you happen to be using CIOKS or Eventide Powermax pedal power supplies, it takes a Type 4 flex cable (the green one). Carry on...
