I got an RM100KH (Kirk Hammet version) with the associated 4X12 cabinet a few weeks ago and I have not been able to dial in a tone that I like. The amp sounds very trebly and shrill without the warm saturated distortion that I'm after. At low to mid volumes it even sounds kind of garbled on the bottom end. The highs and mids sound good, but I have no bottom end for rythms off the low E string, sounds terrible! I play alot of heavy metal and playing rhythm is usually one of my favorite things, but not on this amp. Solos sound great, because it's all highs and mids. I've heard other sound clips of Randall amps on youtube and on this forum and they sound really good, which is why I bought the amp in the first place, but I just have not been able to get close.
After discussing this with the store owner and several guitar techs, I guess my main problem is that I'm not playing the amp loud enough to get the power tubes "hot"? I've ordered a THD hotplate which should be in next week, so I will be able to crank it a bit more. I've also noticed that when I put an eq in the serial loop I can get closer to a saturated distortion sound with some nice bottom end, but I've been using a Boss GE-7 and it seems to rob some of my tone. If I put the eq in the parallel loop or in front of the amp it doesn't do anything. I've already tried maxing the module level and easing up the master volume, and maxing the master volume and easing in the module volume, didn't like either...
From some of the posts on related topics, I've developed some questions:
1) does the hotplate really help?
2) what kind of eq should I use and where should it go in the effects chain?parallel or series loop??
3) KH-3 and 1086 modules, where should the level be? and where should the master volume be?
4) Would a more expensive rack mounted eq be better?
My BC Rich with Rockfield pups actually sounds better than the ESP with EMGs. The EMGs sound very trebly with no "character" and actually hurt my ears with this amp. Any help would be appreciated, my frustration level is pretty high since I dropped $3K on this amp and can't dial it in...
Thanks,
John
Thanks,
John
