Jaded Faith
After a slight delay, I am happy to bring you the demo video for my new Super Clean original module courtesy of Mattfig:
http://www.youtube.com/watch?v=GIY3iEuB3bc
This mod was completely designed from the ground up based of a wish list Matt and I put together. No midgain compromises and not based on any particular amp. Just a pristine clean that is inspiring and fun to play. It is loud and clean all the way up to 10 on the gain, but set correctly (all options on) it can snarl if you should want it to. It has fat, round lows. The mids are hollowed out for an uncongested clean tone. The highs are bright and voiced high, but not piercing. Spank is exactly what it sounds like, adding a Fender-esque spank to things. The Touch switch restructures a gain stage, adding touch sensitivity in spades. You can finger pick a clean D chord and let it drip into an oozing sweet spot sustain, reminiscent of The Edge's eBow work on The Joshua Tree. The Humbucker/Singlecoil switch is designed to make the tone as close as possible for each type of pickup at the flip of a switch. Using it in ways it wasn't intended creates interesting options: Humbuckers on the Singlecoil setting can give a bold push that is similar to many stock cleans and Single or Split coils into the Humbucker setting give a nearly acoustic sound.
Enjoy!
Enjoy!
