sargentcrunch said:
What makes Diezel/Bogner/insert other boutique metal amp here power amps so special? Could a mod be done to an Rm50 to make it similar?
IMHO - a 50 watt amp is never going to get the low end push of any of the mentioned amps which are all 100 watt (XTC / VH4), 120 watt (Uberschall/ Hagen) or 180 watt (Herbert). If you really want that sort of ground shaking there is no substitute for the bass response from a huge power section.
Even from a dual to triple recto there is a quite noticeable jump in this sort of bass response and we can be (reasonably) sure that the preamp circuits are the same there
Essentially the amplification of bass frequencies requires far more watts to get you the impact and clarity that you are aiming for! Which is why if you check out Bass guitar amps even the small ones are two and three hundred watts.
However all is not lost as you can be cunning, try larger cabinets with more speakers, think oversized 4x12?s, like those made by Boogie for the recto or the Krank ones.
Go for large bottle tubes ? 6550 or KT88?s ? these should give you more grunt (okay a bit of a generalisation - sure to get lampooned by the tubes fascists for that one).
Try moving placement of the speakers, point them at walls at varying distances from the wall itself, lean them against walls, isolate them totally from the ground (see Joe Bonamassa?s setup for an example of this, but rather than the auralex ground foam you can use beer crates) etc. and see what you like you will be surprised by some of the differences just from the positioning of the speakers.
You could look at replacing the transformers in the RM50 with after-market upgrades, say Mercury Magnetics, and while this may improve the amps tone I would still think you are simply lacking the number of tubes to get the push that would be on par with the amps listed.
Generally I run a Mod50 (with MM transformers) and for 90% of gigs it can take on all comers with ease. However if I know I?m going to need the sort of grunt that we are talking about here I take my rack (M4->Boogie 2:90 -> 2x1960AV) and I?ve never had any issues making the floor move with that!
