Red&Die
- Joined
- Mar 24, 2009
- Messages
- 28
- Reaction score
- 0
Selling the Soldano Supercharger GTO pedal, Soldano has discontinued this item in 2007, no longer made!
All tube-circuitry! This rugged pedal is built with the same exacting care and high quality as all Soldano amps. 2 - 12AX7 tubes operating at 'real amp" plate voltages provide stable high gain and hot output levels that will make even the most mild-mannered amp scream. Use it as a line driver or an overdrive pedal. Gain, Tone, and Output controls let you run clean and hot (with the gain down and output up), allowing you to overdrive your amp's own pre-amp. Or you can crank up the gain, back off the output, and send a shot of pure Soldano overdrive to your amp or mixing board.
Asking $400 shipped worldwide!
Please PM me if you are interested in!
