more gain with my grail
gwillis
Montreal,Canada
Hi everybody
I would like to known if someone can tell me what i have to replace for more gain. I like the tone but just need a little more gain with that module.
mostly use the grail for solo with my RM100
PM me
thank's
Boost it with one of your OD's. The TS9 or the Zakk OD will work just fine for that. Level up and drive down.
I already have a tube screamer and a OD zakk but i would like to try to mod my grail myself and not add a pedal for my lead channel
rock on ...
rock on ...
I know. They are listed in your sig which I why I made the suggestion.
Lots of pro's use pedals to get that extra for leads. I send my modules out to get modded but that is mainly because I lack the skill set and knowledge to do it myself.
There is a recent thread out there about modding XTC modules and I believe someone posted some links on locations for self modding info. Check that out and it should give you some ideas.
thanks eyeball987 for the informations
the shematic of the grail should be like the recto i think ? if someone
can just tell me the number on the pcb layout for resistance and cap to changes i'll to it easily and it can be fun just to tweak it like i want it.
:wink:
[/img][/list]
The tube primer fearnloating posted the other day would be a good start...all you gots to figure out is the where the cathode (?) resistor/caps are on the Randall board or some such.
http://www.tubenewbie.com/
http://www.tubenewbie.com/tube_gain_stage.html
