NgrungeBB91 said:
Alright thanks for the info. I just want to run effects without having the tone being messed with cause i tried the tremolo in one.. i forgot which one it was. and it really made my amp sound bad and it wouldn't even work in the other loop. The effects loops are really confusing to me haha. Would it be better to run it in front of the amp or is that worse?
I used to run effects in front of my amp for years. There is no problem with it as long as you get some things put together in the right order and everything in line is working properly. I use a GMajor 2 in the serial loop for pretty much all of my effects now. If you read the part of the article by Pete Cornish, the guy who set up Pink Floyd and a laundry list of legendary artists, he talks about pedal order and getting a good sound by buffering the signal. Scroll down on the page and check out : "The Cornish Method" For Eliminating Level Inconsistencies, Tone Sucking, and Noise From Your Pedalboard. If you are just using a trem and delay, I would make sure that the delay is the last in the chain before going into your amp input. You might need to make adjustments to the output level of the pedals to get things balanced. Also, spend some time reading the section on "Pros on Pedal Order". That will probably get you where you want to be.
