New MTS manufacturer!?!
nlstudio
Iowa, US
Sorry for the long post but I thought this might be of interest. Unfortunately, there are no prices or photos. Thoughts?
?Press Release - 2011, October 12. Announcing the formation of MonoTone Modules, Inc., manufacturer of fine guitar preamp modules compatible with the Randall MTS? system. While other manufacturers and modification specialists (known in MTS circles as ?modders?) have been creating modules based on new and (mostly) existing amplifier designs, vintage to modern, they have met the challenge with varying levels of success. Although some of these technicians have a great deal of skill, we at MonoTone Modules believe that their success in achieving fine tone is limited in large part due to the fact that they provide too many options to an increasingly confused customer base. Therefore, our new Mono series of MTS?-compatible modules was born!
Each module in the Mono series has been specifically designed with one, killer, sound in mind. There are no knobs, switches, toggles, or LED lights to confuse the user. Every design is rigorously tested by our ?sound czar? at a professional recording studio using a VERY expensive signal chain, including the best studio monitors currently available, before it is made available to the public. Once the design is finalized, all manufactured units will be preset to the czar?s specifications.
New to any MTS type of product is the addition of digitally controlled Input Modification Technology? (IMT). IMT is always active in the circuit and basically does three things to make sure the predetermined ?optimum tone? is not compromised in any way. 1. IMT detects input level and adjusts it accordingly. If the guitar pickups are too hot, or the volume has been rolled off, levels are adjusted down or up respectively. 2. IMT analyzes the frequency content of the incoming signal and makes adjustments to ensure that the sound coming into the module is as close to optimum as is possible. If the input signal is too far from the norm to be brought up to spec, the module will automatically shut down to prevent user induced ?bad tone?. 3. IMT analyzes tubes installed on the unit and will shut down if an incorrect tube has been installed. Note: IMT is not compatible with overdrive or boost pedals. All adjustments are made in the analog domain.
We make every attempt at MonoTone Modules, Inc. to future proof your investment through constant R&D and improvements. As technology progresses, IMT software updates will be made available from the MonoTone Download Center. Next up will be the ability to incorporate a measurement microphone into the system to allow the process to adjust the final post-speaker-cabinet tone to within our strict sonic tolerances using Output Measurement Technology? ? OMT. In fact, all current modules have a ?? measurement microphone input pre-installed opposite the guitar input jack. The next generation of IMT/OMT will include Musical Content Analysis? (MCA, patent pending) to ensure that each module is only used for the style of music it was intended.
Two different faceplates will be available for each Mono module. Stock faceplates will have a solid painted finish (color dependent on model) with no labels other than the name (?MonoCreamPlex, MonoRRPlex, MonoC30, MonoBlackFace, Mono800, etc. ). The other faceplate option, available for an up charge, will be a silkscreened faceplate with virtual (i.e. pictures of) knobs, switches, toggles, etc. all set to the tone czar?s specs so the user can get a feel for how the modules should have been set if real knobs had been available. This is a good option for the live player wishing to impress his/her fans with his/her ability to dial in great tone.
Initial release of our MonoCreamPlex module is tentatively planned for 2011, Nov 1, with full production of an additional 6 module models slated for early 2012.
MonoTone Modules ? the only good tone is Mono tone. ?
is it April 1st already?
No knobs?
Screw it, I want to control my own tone, not their Monotone.
Exactly! :lol: I was skeptical when I read "There are no knobs, switches, toggles, or LED lights to confuse the user", and I had a few comebacks for that one ready to go. But you still had me - up until I got to the 3rd paragraph (if you have bad tone, the module shuts off? Riiiiiight . . .) :lol:
i agree, this sounds like a joke almost. plus i use different output pickups for a reason, i don't want computers determining my tone and how i get it. don't think this company will last long, if it even gets off the ground.
Heck, I'd buy a mono 800... Gotta be better than some of the Line 6 modeled stuff...
:lol:
crankyrayhanky said:
I'm confused...too many toggles and LEDs in my life
^ This is what I was thinking. :?:
I've never met a knob or toggle I didn't like and LEDs aren't confusing at all.
Options are cool... but more often than not, I end up going with simplicity...
No knobs might be cool, if it's one of those "set & forget" tones (I'm always bumping those chickenheads when I remove a module).
I generally flip through everything to find my tone, but end up leaving any given module in one setting. Without all those knobs and switches, I may not be able to find the "right" tone. That's the only reason I like them all. The versatility once I find my tone is unnecessary. So, I agree with you there.
Too bad there aren't any new manufacturers or modders this side of the ocean that can take advantage of a Salvation type thing where they get the modules direct from Randall and then rebrand and mod them for resale. I still think over 300$ is a lot to pay for a mod...
If I have learned one thing in my time modding both modules and amps for countless customers, it's that I have never once met the player who ever asked for less options. More or less have someone else play God and predetermine what their perfect tone is for them..... :roll:
Agreed Rob! After reading this it made me laugh, no way would I invest in a one set tone module with no knobs nonetheless lol
I'll stick with being "confused" as they put it.
IF it was a set tone that you REALLY liked though, it could possibly balance out the different output level of different guitars (cuz of that IMT feature), for live playing... It's definitely a unique idea. I'd be open to it, as long as I liked the predetermined tone. It may have a use... but what do I know? :lol:
Wow, I couldn't disagree more.
You can purchase a Friedman Brown Eye or Hairy Brown Eye mod for $125. How does a Marsha cost? $3,000.00.
You can purchase an Angel mod from Anthony for less than $500. An Engl Powerball? $2000.00.
And that's just a couple of examples.
I feel very fortunate to be able to have access to close to if not exact replicas of expensive amps for a fraction of the cost.
Amplifiers are expensive. In direct comparisons, modules and modifications are not.
Excellent point... and I DO agree... but to be fair, you ALSO get a power amp & multiple channels with the "real" amps. But yeah, I'm totally sold on the flexibility of swapping out a module... way less money in the long run. However, just as expensive for the guy who only wants one or two modules. :wink:
Every venue is different, I never have had a set tone in my years of playing out - during sound check there's always a slight tweak in settings no matter what at least for me. Plus even if these were released at $200 like most stock mods, no thanks and more than likely with updates via download ability etc I'm guessing prices will be higher than that - I'd rather put that $ toward modded mods with actual knobs and more features :)
