As the subject says I'm new to MTS. I've always found the MTS concept interesting but never tried until now. I found a RM100 for dirt cheap, someone had ran it with out a cab and it was non-functional when I picked it up. I was not worried about it being broken as I'm pretty decent amp builder/modder and I figured the worse would be a blown output tranny, which I had one on hand if it came to that. Tuned out to be fuses, however I could see the power tubes had been arching inside so I installed a new set of jj e34l's. **** this thing sound great! I've played and own some high-end amps, and I'm surprised with the sound of this guy.
It came with one module, an SL+, and I'm pretty sure it has a foglifter installed too. I have modded the SL+, put a .0022uf in c3, and did the jcm800 tonestack mods on a toggle. Thinking about installing better coupling caps. Any suggestions? mallory, sozo's? I did try OD's and while they sounded neat, they took a lot of the marshal vibe away.
Also what power tubes do you guy's suggest? I't came with a pair of jj kt88's, and a pair of ruby el34str's, these tubes are toast so I don't want to experiment with them, I have JJe34l's in right now.
Oh and I need more mods, sell me some
Thanks
Thanks
