I am having a problem with my RM20 combo, any help is appreciated.
At louder volumes, on certain notes, especially high B if I let it ring out, the amp intermittently cuts out to a loud hum when I play the note. The hum sounds like I pull the cable out of my guitar and touch the jack while its plugged into the amp, then cuts back in when I play another note
Here are some things I tried:
1. I swapped out the tubes, but still had the same problem.
2. The problem exists with several different modules (ie, Plexi, Ultra Lead, Top Boost)
3. If I plug the module into an RM4 preamp, and patch it to the effects return of the RM20, the problem seems to be pretty much eliminated.
Because of #3, it would eliminate the power amp section of the RM20. It is probably not the module, since it happens across several modules and does not happen with the same module in the RM4.
It would have to be related to the preamp section of the RM20, or a vibrational problem when the module is in the RM20B is is eliminated when the module is in an external enclosure.
I know this is kind of a quirky problem, but if anyone has any experience with solving a problem like this, any help is greatly appreciated.
Jim
Jim
