i got a used rm100kh about 3 weeks ago. it has a manufacture date of 10/2008 if im reading the serial # right.
just went to use the fx loop at its acting funny
summary after a day of fiddling:
original post:
1) serial fx loop: doesnt do anything. no matter what i plugged in or did with the fx mix knob
2) parallel fx loop: fx mix knob works; when i plug a distortion pedal i get a strange sound like a sine-wave. as i adjust knobs the pitch gets higher and lower. similar strangeness happens when i use my typical fx rack unit in the loop.
if i run my guitar through a modeler preamp, into my parallel FX return (uses the head as simply a power amp) i get an expected result which sounds great but obviously bypasses the entire preamp section of the rm100
swapped all 3 preamp tubes in the back. swapped what i believe to be the fx loop's preamp tube multiple times (the tube closest to the back panel, farthest away from the poweramp tubes)
should i bother taking it apart to see if i can find anything bad? will this void my warranty? could it be a fuse?
eddie
with the guitar plugged into the input jack of the amp, my rackmount EQ unit in the SERIES loop. no sound change. nothing
if i switch to parallel and turn the input gain on the eq unit down a little bit and play, then gradually turn the input gain up, once i hit about 0db, i start getting this squeeling like a sine-wave or something. as i turn it up more it gets higher pitched. as if i were going through a whammy pedal you know? the same thing happens when i plug in a distortion stomp box pedal. as i turn the gain up it starts giving me that strange whammy pedal effect
other scenerio:
if i plug my guitar into my rackmount preamp distortion/fx unit (digitech gsp2101) into amps FX return, it sounds wonderful through my 4x12 speaker cab. as it should since im bypassing the amps preamp section. if i go one step further and run a line from the FX send to say, my computer to record, it sounds fine again. perfect on BOTH the SERIAL and PARALLEL
so from what im observing, the fx loop send/return works when you feed from an external preamp, but not from the internal preamps
there are 3 preamp tubes. one as a buffer for the preamp modules. one for a phase inverter, and one for the FX loop. ive changed all of them out
original post:
eddie
