rm4 short
mesatwin
Nashville tn
I see I am not the only one with this problem. Lucky us!
I have a global short, effecting all module s. Using either inputs, and any of the outputs, its F 'ed up! the vol. will cut down too bout 50% , and sometimes 10-20%. Usually if I press the channel selector button,& slide my finger it will come back, or cause it to do it in the first place But this us not alaways the case some times I dont change channels at the solo, w/ft pedal. I come up to solo volume and on down of the first note gone. So I slide my finger off the channel swith on unit and let it pop out and... And then I quickly bypass it and my pandora px4 as a preamp
So another issue I ve had with channel selection, like the logic in pre amp and ft. ped
Just reassign theirself to respond to different ft. ped. Butttons.
So I wonder if the two are related ? The input / channel select are on the same input board. The input signal chain in the rm4 does have a short protection , where it mutes the signal if the is a short. All tubes and caps checked ok , I ve had it to the repair guy
(Todd Sharp at nashville amplifier service the best in town) twice he cant find does nt think it has a problem. It took 45 mins for me to get it to screw up when I got it back. Please not that with this bypassed I never have issues.
So has neone fixed there s yet?
